Custom/Hybrid Wasserjet, Rotary Engine teaser video
Quinc
Buy a Superjet
California
It actually works completely different than that Stihl, although that's a good link. This Woelfle motor is a proven motor and should work great if these guys can get it to mass production at an affordable price.
Maybe yamaha will pick it up and put it in the sj.
Quinc
Buy a Superjet
California
Wasserjet To Exhibit At 2014 Jettribe World Finals
http://www.ijsba.com/2014/09/08/wasserjet-to-exhivit-at-2014-jettribe-world-finals/
Quinc
Buy a Superjet
California
What are we "gaining" with this engine? Power to weight? EPA pass? Just something different?
All of the above. =)
Rotary Weight: 40lbs (Not including starter or TBI)
Power: 120hp Natural Aspirated (Turbo estimated 200hp)
Torque: 50ft/lbs @ 3500RPM
Displacement: 600cc (1020cc 4-stroke equivalent)
Yami-Rider
TigerCraft FV-PRO
Texoma
Turbo's don't work great on pwc. A crank driven supercharger would hold up better imo. Wonder if this would be a torquier motor then a limited 701 setup?
Melmack
(Timothy)
More hp less torque I think. Its a trade off but the weight savings makes up for that. There is no bulky exhaust too. So its like cutting the weight of the power plant in half.
BrightE's
Paul
Seattle, WA
Wankle's have higher RPM limits too right? For a freestyle application down the road is it mostly just a matter of utilizing a higher RPM range (for low end bursts) and propping down at the same time to compensate for the lower torque values?
So the rotary power characteristics will not be affected by exhaust system changes or require sonic waves to facilitate a "supercharge" effect? Sooo, provided exhaust system will be the end all with no money spent needed to gain performance?
yamanube
This Is The Way
Staff member
Mandalor
Assuming the torque curve just flattens off at 50ft/lbs this would put the peak (120) hp at roughly 12,600 RPMs and provide 33HP at 3500 RPMs.
King Kang
Never enough tray time...
Cary, NC
No, I'd imagine that there will still be a ton of aftermarket exhaust options. Think of how many performance exhaust systems exist for cars.
You're right about the expansion chambers though. Four stroke motors are efficient when it comes to fuel burning, so they won't benefit from the sonic boost that an expansion chamber provides to a two stroke. Two strokes experience that boost because a lot of unburnt fuel gets past through the exhaust as the piston goes up. The reverse sonic wave blows some of that fuel back into the combustion chamber where it has a second chance to burn.
My point about the exhaust, was options from the aftermarket providing 20+ HP gains, like a FPP SXR dry pipe for example. Surely there will be people peddling exhaust for these, but if the factory is good, with A/M providing say a 3-5% gain then the engine will be a value out of the box.
