KR
www.krlines.com
- San Diego, California
What are you doing to take the foam out? Sounds like its taking a long time. I cut, defoamed, drained water, re-foamed, sanded, and glassed 2 hulls in two days.
I am pretty sure the hull was assembled by WDK. Yes it was 2 part foam and I did find quite a few voids and quite a few areas where the foam didn't mix/kickoff properly and it was chrunchy and bubbly. There was an air void under the front of the tray and I could easily flex the bottom of the tray with one hand, it will get heavily reinforced when I put it back together.
I was planning on putting in poly with a pair of drains.
just use inner tubes and a pair of drains. put the valve stems though the back of the hull just under the tray ledge. pop open the drains, air up the gunwales, close the drains.
