Mile9c1
X-H2O.com
- Grand Rapids, MI
SuperJETT said:Sure you can, you build a bigger cylinder that has the proper proportions of transfer port area to displacement.
Well you can do that... but which cases are you planning to bolt them on to? Definitely not 62T cases. You can't add much transfer volume between the two cylinders because there is only a thin wall separating them. And like Romack said, you still need cooling ports in your cylinder.
Here's cases for an Able cylinder, they've pretty much maxed out the transfer volume, the porting actually cuts into the flywheel area (see where the epoxy shows through).
