Mr Bojangles
Lord of the Dance
- Brevard County, Fl
I am off to another project! I am upgrading my SN to a carbon watercraft factory hull! This was used mostly as a frestyle hull (some may recognize it) and now I am going to turn it into a surf hull and a hull for playing around on flat water. I wish I could do a quick build, and have it ready for daytona, but I am in the process of moving, (see mess in garage) so I have to move before I get down and dirty, so now its just going to be getting the hull ready for glass work and paint. I plan on doing the wide bond rail mod like ScottS has done to his SJ since the rails have been cut off this hull.
This is the plan............
WCF Hull
tubbies
either glass over the scuppers and put in drains with screw in versiplugs, or just run two versiplug max's
lowered bracket
new pole
upgraded bearing steering
internal fuel fill
paint
turf
front foot hold
And transfer my motor and pump setup from my SN
I am sure I am forgetting alot right now, but I will post everything as I go along slowly first, then ramp it up!
WCF Hull
tubbies
lowered bracket
new pole
internal fuel fill
paint
turf
front foot hold
