I pulled the stock siphon back out, and added alot more tubing to it, and double checked the hole and it looked good.
Wilkwy, I just rebuilt the midshaft, and silicone the shaft housing to the hull, when I looked with a inspection mirror on dry land, it still looked like it was in good shape, but I need to look in the water and see. The midshaft, and scupper tubes are the only things left to leak.
I made another set of wide rails to test out on the hull, took the 5 min to unbolt the first set, and I just need to dill new holes, and bolt this set up.
