Custom/Hybrid Welcome to Alabama
pump is in.... hmmm..maybe I'll put the motor in and get it lined up tonight..
Was the rear lip cut off when you got it, or did you do that?
And is this a visual carbon hull, or 100%?
(I ask because of that white layer visible at the bondline)
Looking very nice, by the way. That must be an ear-to-ear grin the first time you ride it.
Congratulations.
Congratulations.
The rear lip isn't cut off. It is full carbon with some other stuff in it in areas for reinforcement.
GReenANt
GReenAnt
Indianapolis
kinda stinks they have a dip for the fuel fill considering most people will be using internal fuel fill (unless its a Wamilton's option) and you would have to smooth it over with some body fill and paint the ski (bodyfill = unnecessary weight especially after paying that much for a hull)
Exhaust tube and Factory Pipe waterbox in. I forgot about needing my exit nozzle bored since it was new with the trim, so I had to pull it back off of my pump. I got it out to Tricky via fedex today to hook me up with an 86mm bore.
