- NYC/Long Island
Cut it open and get the wet stuff outa there, replace with poly or sheet foam and then install 2 small drains in rear of hull.. Its not as bad to do as it seems.
Good. I'll drop it off tomorrow morning lol.
I looked where the intake grate bolt was removed. It's still leaking (slowly) since early October and lots of salt on the floor left from evaporated salt water. My concern is, OK I cut the tray and remove the 2 part foam then I replace the foam with home depot foam. Inevitably there will be air voids. Wouldn't this compromise structural integrity of the tray and need gunwhale reinforcement? This is surf ridden and hopefully soon learning barrel rolls..
