JK, there might be a couple of things adding up to create this issue. Besides the cases, the crank should be checked in V blocks to make sure it's running true. If things get a little twisted, there will be all kinds of forces working against the bearings. The front and rear bearings (outer shell) of your crankshaft look like they had a hard life for only 8 hrs?? They appear to have been not clamped by the cases 100%. If the crank checks out to not be twisted, you can probably clean things up, check for case half flatness, and use a little bearing retaining compound, (along with the dowel pins that prevent bearing spin).
