Surfriding What the heck is this? Whatever i guess ill build it.
air blair
you are the reason
Ihope soooo, workin on her now. Waiting in a pole bolt and run pissers,fuel and pump install.uploadfromtaptalk1378832517806.jpguploadfromtaptalk1378832542778.jpg
I was gonna use a mount ltd was to send and his pole but i waited to the point where plan b is in effect. So pole bolt is all i need now.
Sent from my SPH-D710 using Tapatalk 2
air blair
you are the reason
I just checked. Tomorrow for sure. Ill run a threaded rod or something for a test run hopefully a little later. Good sign i got spark. Lol
Thanks for the quick ship kyle. U the man
air blair
you are the reason
Darnit, spark when i hit start and when i stop hitting start nothing in between. Picked this msd enhancer a while back. Dont know how good she is. If it is good
air blair
you are the reason
Just switched start stop. Still shizzit. I guess ill tear into ebox and double check connections but i hear its common thing with the enhancer when they are junk.
air blair
you are the reason
Msd white wire male needed to go to red white wire. I had it reversed. Always learning the hard way. Lol. I got SPARK!!!!!!!!!
air blair
you are the reason
This kuwait landfill savage ski is just an awesome ride. Couldnt be much happier with it right now. Turns amazing. Carves great. Subs awesome spins nicely. What else could u want.
Awsome I still can't believe it came out of a landfill :D
