- South Africa
Brand new from manufacturerYou inherit a DIY disaster or was motor from a company?
Definitely changing my machining guy, prefer threaded joint and welded V-seam. Places here don't do full shafts.All the new power uncovered the weak link...or coincidence. Either way that’s a bummer, maybe time to get one resplined at the correct length from a one piece blank rather than sectioned and welded
Custom length shaft for my skiWhat’s wrong with the oem versions? Are they not strong enough?
Price more or less?I make custom length shafts from oem shafts, no cutting or welding. Splines are perfect and new. Cut the same way Yamaha does it with the correct spec tooling.
