- Houston, tx
That ski is definitely worth $400 if it turns over. What is he asking for it? Sounds like a few decent parts are on it, and like mentioned before, worst case you could part it and make some money. That pipe is $300 or better depending on if the water screws work. PJS nozzle setup is worth $100 or more, head is worth a few bucks, you'd most likely break even at $500 on that ski (less your labor). Top end jobs are quick and easy, $250-400 for a top end kit depending on pistons, $80-$100 for the bore and hone. It sounds like you are familiar with working on 2 strokes.
water screw? where would that be? is it this? how do i check it?
he just called me back and asked if I was interested still.
dead link
