- Cleveland Ohio
...and how do I order one? I did a search, but found nothing???
you should also look into the wamiltons setup...it uses 2 rubber straps, is very convinient (and holds the hood extremely well)....seems like ratcheting/unratcheting would be a pain.....
add salt water to the mix....could make things worse.....
Its really simple, just takes getting use to.you should also look into the wamiltons setup...it uses 2 rubber straps, is very convinient (and holds the hood extremely well)....seems like ratcheting/unratcheting would be a pain.....
wammers will loosen over time
every rubber strap ive ever had stretched with time....actually they dont...
