C-Rock87
Water Junky
- Boise, Idaho
i can totally understand where you're coming from bro, i would be upset also..i do believe in forgiveness and second chances though..have you called him and had a talk with him about how you feel?
I like your support for him. And I love what he does and has done for the sport.. All the freerides, ect. Helping people. But how would you feel if he strung you along like me? Could you put it aside and send him $1000 and motor parts?
Scott, (Bombthreat) Sorry your troubles are continuing. Let me put a little insight into this from my side……………..
Sometime in April, I received a call from you asking if I did dome work for a stroker motors. Which I responded yes. You stated you had just purchased a 5mm stroker motor used & wanted to change some things. (Also included this in a note when you sent me your parts) Ok, I would need to have the original head to copy from as to not make un-necessary mistakes…… you sent the parts
On 5/22/07 I received your parts, At that point I assessed what needed to be done & contacted you directly to confirm.
Wrong, I always had to call you. You phoned me all of maybe 2-3 times through the entire ordeal. Also the parts were shipped I believe April 26th or 27th. Go with that and you'll see there is one part of the no communication periods.
It was decided that the depth of cut would make a Riva dome exceptionally thin & the chance of cracking would be too great, I suggested going to a ADA head, as the domes are much more substantial… agreed!
I quoted you a price of $365 for the girdled head kit complete & a cost of $20 per dome for the special machining required, total to you including return shipping $427.00
Job was completed & shipped DHL on 6/12/07
Sometime on the week of 6/18, you contact me back stating the compression was in the 135 range??? OK, I said, let’s see where the problem is… I ask you to perform a squish test…. Way out of spec? We determined that the person who supplied you with the motor, used a .040 head gasket, where there shouldn’t have been. When I cut the domes, I included the gasket dimension, as part of the total depth? I told you to keep the domes & feel free to run the motor, as all that will happen is it will run underpowered with low compression, at least you can ride. I purchased new domes and but did not charge your for those.
It was never told by you to keep the domes, you asked for me to ship them back. I didnt. I wouldnt run the ski with 135psi anyway. It was doggy and most likely not good for it with the timing ect. You asked about the gasket and the riva head that was orginally used had the stock gasket. The head did not use a o-ring and you knew this becasue the head I sent you had the gasket still stuck to it.
At this point I didn’t have blanks in stock & needed to order more in, That & I was to be going on Vacation the following week, 3 weeks were lost…. It was during the busy season and therefore the turn around was a bit slower than before when I shipped it in June….. It happens and I apologize for that!
Yeah I remember that. There wasnt any communication from you, other then it was suppost go get done in 2 weeks. I had to call you, by the time I did you were going on vacation... Tough luck for me I guess.
I ask Scott numerous times for the dimension the piston rises above the deck? I was looking for a good set of dimensions to work from. At this point, any outcome will depend on what he gives me? Domes are cut & shipped
.083 is the number, I took the messurments over and over to be sure.
Here is the crazy part, I ship the new domes DHL, and the domes arrive at the address I was given, but were Refused at the door????? Scott calls to see where his domes are & I track it & here this? Domes arrive back to me about a week or so later & I reship to same address priority mail….. Same issue ???? By this time over a month goes by & he still doesn’t have his parts…
I refuse to ship back, until he gives me an alternate address so this doesn’t happen again. He gave me a different address and I ship his parts back to him on 9/5
Post the tracking numbers for all the times they were shipped. B/c i never got any from you when asked.
I never heard anything back from him until now………..
In conclusion, there are several things in hindsight that could be effecting what has gone wrong. I was told this was a 5mm stroke motor? This post is stating 4mm???
Scott is stating .12 squish??? What is that? MM? Inches? Don’t you mean .012” ??? This is why I asked several times what the measurements were?? In hindsight, I should have made sure you were able to take the measurements needed………
You knew it was a 4mm stroke instead of a 5mm like I orginally thought. Thats how we came to the conclusion the first set of domes were way too deep. I took the measurments just as you instructed. I may not know a ton about building motors but I can follow instructions. Even so, why would one piston by 230 and the other 240 with the current domes. Its not a bad piston, the other head has 215 on both.
I’m sorry you feel like you never want to deal with me again? Of course that is your choice. But with all my work, I stand behind it.
If you will take squish measurements, along the Piston pin line, on both sides of each piston, along with marking the solder, as to position, send me the domes & the solder, I will recut your domes & send them back, no charge!
Paul
I've been calling around the engine shops and all seem to know their stuff and priced around the same.. I want to know your real opinions on them and if you know of any other places worth your recommendation. The engine will be for freestyle/rec use and get full porting for a stroked motor.
what good is it to "try to make peace" and then come on here and start trashing all over again?
:censored::tapedshut:
Customer, Dealer & Sponsored Rider always Wrong !
Unreal !
I have personally emailed Paul to make peace, so freerides wont be a problem.
And what you are suprised that he didn't return your email???... Really Pete - can you be that dense?..... Considering who really lost their temper on this site in the last what 8 months numerous times - I don't think anyone has to worry about Paul at the freerides.... but I certainly can't say the same for you.... You see I read your email to Paul and also your threatening PM to me....:eek5:
Paul just likes to lie more, he is never wrong..... I am one for keeping really accurate and very precise records on all transactions for LPW.... :wavey:
This is great... Guy riding 2 hrs, like half my crew... Thats Great for the sport !
I did not post this... But for a sponsored Riders motor.
It was an 84.5 mil BB, and after like 30 hours, it craped out
and when I measure the cyl. it was 85... and I dropped an 85 mil piston in the cyl... fit but still needed the clearance.I think I will leave Paul to comment on this one.... Just to clarify - would this be the cylinder that Paul bored in Fall 2005???
You think for a sponsored rider, you would at least even check things you put out... I dont see this suprising, but Sad !
For all you that have LPW motors, Good luck !
Damn if you do and damn if you don't...... Sometimes you just gotta engage when you are SO TIRED of this bs....:moon:
Actually the sleeves cracked, didn't drop..... please if you are going to quote - try to stay accurateBecause the guy can beat everyone else up, and Lie.
and then you try and make nice and he trys to make you
out to be the Liar ! SO I am not holding back.
I am assuming that you are referring to you making nice with that so called "peace" email.... and then Paul making you out as a liar..... I'm sorry I just can't follow this logic.....
I go so pissed, when I see so many people that get beat.
He does'nt want to make any Peace and lies to others.
So we are back to the fact that he didn't answer your email.... again I don't see the point in why that is a big suprise..... So that gives you the right to keep doing this over and over and over and over and well you get the picture I hope
Fine with me... but when threads like this and he always
makes others out to be wrong... It said and this is what
I call the "Paul Blinders" Because he will make you think
that others are wrong....
Sluttys motor blew in daytona, Paul told the NJ crew
that Nick did not put pistons in right...
Well that was not the case... the sleves droped.
PAULS fault, but makes it other peoples fault
and makes people believe that he is right and
others are wrong..
:argue: I really hate myself for stooping to this level....
:Banane57:Your a Lieing sack of Shiot !
Be careful Pete - you're not being nice
what threating PM ? lets see that !
Make some more crap up !
I don't make crap up Pete - you should know that by now - I never say anything that I can't back up..... Since I follow the site rules and you don't really seem to - I can't post a pm.... but I will give you a little hint.... Something about if post anything more about friendship or bs like that you would do something in return...... Remember now Pete?
the one paul bored in 05, WTF are you talking about.
Ya... you knew him then too right, and saw that cyl.
I'm sorry you should excuse my ignorance - I am talking about the last time we bored your cylinder???
You Dont know Crap Kathy except the BullShiot Paul barks to you.
You underestimate my intelligence Pete.....
SO why dont you stop defending crap you know nothing about...
GO bake some Cookies... that is the only thing that will keep either one of you afloat !:shooter3:]:haha::haha::haha: That was a good one Pete.....![]()
It did not matter what happen to engine....
I disagree Pete..... if you are going to go off - make sure you have your facts right...... That's very libeous
He blamed Nick instantly... Be careful Pete.....
