- South Florida
I did 1/8 npt brass fittings fiberglassed into the bottom rear with a little cabosil and resin and the little 1/8 npt brass screw plug. Available at Lowe's/Hope Depot for super cheap.
So what is he saying to run in there?i just got off the phone with wammer and he said dont do it.(no foam) he said it will handle like a wet noodle. lol. now i am confused!!!!
Update:
Now I will fill with 2lb foam for flotation and some rigidity.
Update:
Here's what I decided in the end. I really really don't want my ski to sink, so I'm not going the no foam route. I have reinforced with a 6" strip of 1708 biax along the bondline then full coverage 1708 from nose to tail. In the rear I added a layer of 8 oz e-glass for good measure since I had some lying around. That's where I've had some cracking so I wanted to make it extra strong there. The tray is put back in the same way - 1708 biax tape over the seam ans a layer of 1708 over the whole thing. I also have a layer of 1708 biax and three layers of e-glass under the pole mount - should be pretty tough!
Basically this is a very tough boat for flat water and occasional surf. Now I will fill with 2lb foam for flotation and some rigidity. I wouldn't go as light as 2lb normally, but with the reinforcement It will be plenty.
I haven't weighted it yet, so it will be interesting to see where it comes out after foaming. I was 114lbs in a similar state before the defoam/reinforce. Will have to wait till Sergio ships my footholds before I can put the foam in and weigh though.
Thought you were going with REV's?
You mean 2lb sponge for flotation? The us composites stuff is ok for filler but unless you want to refoam it before the season is over, I highly recommend you use mostly polystyrene. Half a season on my SN with brand new 2lb foam and I had gained 40-50lbs in water. Closed cell my @ss...
As much as I hate to say it, the WCF footholds are the best I have used.
Dont like the idea of plastic bottles.
I think the plastic actually leaks a small bit over time.
