That pitting was from the timing cover leaking. The inside of the motor is clean, and the bearings roll really smooth with no noise.That looks like water intrusion damage to me. From what i see in the pics there is a lot pitting on the crank and the rust on the bearings i would say you are getting water in the motor.
Please explain this ? Thanks.I extend an oil passage in front of the bearing.
That's what I thought. So when this cracks or disintegrates, it makes them unusable right?
Looks like it holds the balls in place to me?
I only have one broken on right now
It looks like the bearings will bind up when they hit each other from not being retained. My 66V crank has the same problem, and I'm scared to run it that way.I wouldn't run one in my own ski. But I have pulled running skis apart with bearings that looked like that. They will last a while on a stock boat that doesn't turn super high RPMs.
Does this mean that it is caused by lack of lubrication on the mag bearing?I extend an oil passage in front of the bearing.
Thanks for the info,The black plastic does act as a cage to seperate the balls. Its hard to say why they fail and crack. Could be heat, lubrication problems or the crank moving forward and backward as the bearings wear. I see this every so often even on clean looking oem cranks.
Sent from my SAMSUNG-SM-N900A using Tapatalk
I never thought that it was adequately served by the stock oil passages. I extend the stock passage to assure the bearing hole is not covered and cut a channel to the front side with a 1/8" ball file.Does this mean that it is caused by lack of lubrication on the mag bearing?
Please post up a photo of your case mod if you have one.I never thought that it was adequately served by the stock oil passages. I extend the stock passage to assure the bearing hole is not covered and cut a channel to the front side with a 1/8" ball file.
