this is what has been done.. went to put footholds in and foam was wet. then i defoamed.. then i just went for it... slutty mod with my own scotty slutty,,, 1" gunwale cut and 15 degree angled out rev footholds... ran 2" oneway valve and second cooling line.. taped exhaust manifold and pump. i have never done fiberglass work. i have ordered west sysems epoxy and hardner biox sheets.... 404 hardner.. 3m sealer.. i want to put closed cell foam on bottom and 4 lb on top with drains... i just dont understand how to make the floor tough when you dont foam in the bottom half|?? if anyone here could give some tips for what im up to it would be greatly appreciated. measures 14.5 up front and is 20" inside foothold.. i will post the rest of this poject
