- Loveland, Colorado
What are your plans for mods?
The small pin has higher RPM's. Mine runs great with that single. My big pin with dual carbs runs tits too. Better lower end though with the big pin. My mechanic says to get a Intake that will adapt to a Yamaha dual carb set up. Runs way better.
Small pin 750s are ported better for low end, so it should hit harder on the low end then your big pin, but the 750 small pins came with small stock single carbs. Yamaha dual carb setups are sbn 38's. 750 Big pins came with cdkII's, which are supposed to be 38's, but are truly closer to 32mm, so the sbn38's would give a little more power. I prefer mikuni over keihin also.The small pin has higher RPM's. Mine runs great with that single. My big pin with dual carbs runs tits too. Better lower end though with the big pin. My mechanic says to get a Intake that will adapt to a Yamaha dual carb set up. Runs way better.
well, I'm not really sure yet. I originally didn't think I would have to spend this much on the engine. So for now I just want to make the engine perfect. And i already have some of those handling mods in the pictures. The only thing i might do is get my flywheel lightened that way i don't need to take my engine out again during the summer. After i start working again during the summer i plan on getting an exhaust (not sure yet, i want the factory pipe for a 750, does it fit?) I'm also going to be doing things like getting rid of the fuel selector, adding in-line fuel filters, and little things like that. Also, the main mod is dropping in a 750...What are your plans for mods?
yes it will fit but you either have to bubble the hull next to the head pipe or find a 650 westcoast exhaust manifold and bore it to a 46mm for proper flow. Here is a link to thread I started awhile ago on the factory pipe. Vumad makes a very good explanation in it "what needs to be done to make it fit."(not sure yet, i want the factory pipe for a 750, does it fit?).
Yes, i know that's the case for an x2, but I have an sx...yes it will fit but you either have to bubble the hull next to the head pipe or find a 650 westcoast exhaust manifold
