winter project
baldwin ny
i have ben slacking on the x2. i did glass and foam in the left side tray and half of the right side (ran out of foam)started to cut the turf . i will post some pics later. heading out to work on it now. i still need to seal the exhaust tube to the hull inside.i had some of the bonding glue from kawasaki i used that on the drain tube and the back of the exhaust tube.ran out of it. going to use sxi-10 from west to finish.
cut the front gas fill out glassed in the door. removed the water box (dont think i will be useing one). i may try a superjet gas tank or a have an old large 550 westcoast tank.
BruceSki
Formerly Motoman25
Long Island
you gotta make the blaster seat mount up now... that looks good.
i saw your glasswork on the x2 in person the other day... its looking good even though you say you suck at glasswork. you don't need to pay tommy for that... just do it yourself, its not hard. the sanding is the hardest part.
baldwin ny
i know how to do it just dont want to.
the seat looks cool right? i may have to try somthing. i just stuck it there to get it out of the way.lol
baldwin ny
all most got it done and running tonight. rizzo put a timing advancer in befroe i got the motor from him. well bolted it all in exhaust all done tank in batt tray and batt in ele box mounted line runs,bars,start/stop,throttle. go to start it and it just cranks no spark. ok swap out the box (i only set up like 100 of these ove rthe years) figure i may have pinched a wire or somthing. nope new box still no spark. pull the stator. rizzo put the advance on backwards lol. never in my life have i seen this done lol. .i knew i should of checked it before i put the dam ski all together. waisted all kinds of time dicking around with it.
RIZZO DONT USE ANY TOOLS !!!!!!
Woody
Need to save my money!!
Long Island
lol you gonna put a big ass purge kit out of that hole in the top left of the ski? or is that where those things gas caps are?
baldwin ny
still have glass work to do on the hood. old truck is giving me a spare hood to cut up so i dont mess up mine (yet) lol had it running tonight dam its loud!! mite have to put a water box up in the nose.
next is a quick test ride. anyone want to go to the ramp? dam its coooold out.
after the test ride i need to pull the jet pump and go over it. going to run 1 1/2 cooling line. motor is mostly stock. i have a 3.5 mm stroker crank i may put in this boat if i like it.
p.s. thanks for the bars bruce they look good!!! i have to cut the grips off put my trade mark set of grips and bar ends on.
i spent the money i had for turf on the ramp project for daytona lol. figured i didnt need turf right now anyway.
BruceSki
Formerly Motoman25
Long Island
just unscrew the grips(4 hex key bolts)... they are basically brand new. i'll put them back on the shelf.
bars do look pretty good though.
i thought you meant you fired up the roundie last night when you said it was loud.
go to the ramp today. it was 60 degrees at 430 this morning its got to be pretty warm by this afternoon.
baldwin ny
running as of tonight. still need to strap the ele box in. i used a 650 sx gas tank it fit with the exhaust wraping around the front much better.got th egrips off (didnt cut them lol) carb is way off on the jetting . ran it sounded rich on the trailer so you know its way rich. had 157.5 high speed and a 130 low. 2.3 needle 21 lb pop off. i just droped the main down for now to a 135. sounds better need to get it to the water. hoping to test it sat or sunday. quick ride at the ramp.pix later. tired
