The Penguin
triple secret probation
- down by the river
I'd be interested.
I could think of somewhere for you to stick them......:haha:
JK had to say it.
Cool Idea,but yeah maybe some bluetooth?? there are magnets that might work,like the ones companies use for gates.I had one when I was driving a truck that would work from ten feet. Also what about the technology inside the toll road prepaid things?? Just some of my random thoughts:bigeyes:
[FONT=Impact, Arial, Helvetica]RFID Proximity Kill Switch[/FONT]
[FONT=Trebuchet MS, Arial, Helvetica]If you get too far away the boat shuts off.[/FONT]![]()
[FONT=Trebuchet MS, Arial, Helvetica](+10)[/FONT] [FONT=Trebuchet MS, Arial, Helvetica][vote for,
against][/FONT]
[FONT=Trebuchet MS, Arial, Helvetica]PWC and Boats come equipped with "Dead Man" or "Kill" switches that use a physical connection between the operator and the craft to shut down the craft's engine if the operator falls out. The problem with a physical tether is that it doesn't allow one to move about the craft while in operation.[/FONT] [FONT=Trebuchet MS, Arial, Helvetica]This is an RFID chip in a wristband or other piece of clothing that will allow the boat to run only if the tag is within range. If the tag goes out of range, the craft will shut down until it is manually reset with the tag in range.[/FONT]
[FONT=Trebuchet MS, Arial, Helvetica]It’s a tether switch without the tether.[/FONT]
I'm sure a magnetic solution could be viable using a magnetic wristband, but it seems it would not allow you to remove your hand.
I would think for both a transmitter and receiver, somewhere around $150
Hopefully less with large production levels, but you only get good price breaks at 1000 units for the various IC's required build them. Part of the process is encapsulation in epoxy, so yes, we can gaurantee a 100% waterproof solution. Again, epoxy is not cheap, but there are substantial price breaks with volume.
We build deceleration lights for couches at www.jetskibrakes.com
And waterproof audio systems at www.fullwaveaudio.com
We are currently working on waterproof 2 way radio communications and some other projects as well. A reliable proximity solution is a peice of cake...
