AZRIDER
stupid desert
- TUCSON ARIZONA
the easy way to defoam....
i believe you would be correct bu Im going try and adjust iin different ways-- pump is going o go as far forward as i can get it and the fron of he foot wells might have to be brought back according to my reconingHave you measured the difference from pump to bulkhead on these two setups? Your probably going to need a midshaft thats longer to get the motor forward enough to let the pipe and carbs clear the hull.
Its not going to be easy to ride...That's gonna make for a loose ski...sounds like fun!
Nope...is a stock 701 going in?
Plans change...... all I have to say. Installing a whole super jet bottom was decided a little lateWhy the carbon then cut? Wouldn't it have made more sense to add the carbon later?
