xxx2
Reply hazy, try again.
- panama city beach fl
:banghead: Here's my problem, The ski will start and rev to about mid throttle, Anything over that it bogs bad. On the water it starts fine, It even hits the powerband Until about half throttle then it bogs. I tryed riding around with the hood turning in and out the high speed screw, With little luck
:banghead:
Now that I am back from Daytona and at my shop, I decided to take the carb apart and check it out.The carb is clean, But I am not sure that the jetting is correct and I know the pop off is to low (about 12psi:frown: )
Here is the current jetting on my X-2(44sbn) 100L, 125H, 2.3 N&S, with the silver spring. I will admit I don't Know alot about tuning Jetski carb's so these numbers may be way off.
Now here's the ski, 89' 650 X-2 Mod's are: 44sbn, Westcoast intake manifold, Ocean Pro head (190psi)(BR8es), Coffmans manifold and pipe, Westcoast water Box.
AnyBody have any thought's on my problem or what I should be running @ or around? Thank you for your help:hail:
:banghead:
