I have some, just hate the way it cuts. I have used the mouldings before at work, and the chit just almost melts when you cut it. I was going to use a big piece of 1x6 to mount the steering stem on to cover the old hole and raise up a bit on my x2.
Wouldn't rear sponsons do that? It's just a rudder which is basically what you're making with your chines. If you make the rear sponsons so they bolt into the bond line, they could even be removeable.
Exept I cut the rear corners off the ski like so many do, so there is no more bond line there.......did't realize how much it helps hold the back from sliding out, but do like the fact the corners are gone and don't hit you in the gut when side mounting.
