- Montreal & Boca Raton
I tried my new (used) ski for the first time and it cavitates like crazy. When I came back in I only had 2 bolts left on the intake grate and it was loose. I changed the grate to a RRP to see if it makes a difference but not really and I'm also waiting for a new pump seal.
So here's the problem in detail: When I hit the throttle hard from stopped or before a set up wake, the engine spins and I don't move at all. If I am stopped and give it, I feel some rumbling under the tray instead of a smoother flow I am used to and it barely moves forward. If I give it less and lean forward enough I can get decent speed, but then it porpoises - I figure the two are connected or the same?
Just wondering if anyone else has had this problem?
I will pull the pump tonight and check the seal. Hopefully its just that...
