- Atascocita
Yeah...Looking closer at the pics of Little_franny's subplate, it is slightly different than mine. I am not going to be able to reuse the stock pivot location, as it is too far from the bump stop. Only way it would work in that location is if I drilled a couple of short bolts through the sub plate that could stick out a bit and make contact with the arms on the turn plate...basicly making a new bump stop for each side. This is probably an option.
My other option is to take the sub plate off and see if I can remove the stock pivot bolt, maybe that is what madscientist is talking about a few post above. Then I can use the smaller hole that is about an inch lower and run a new pivot bolt through it and mount it up. Then the turn plate will be closer to the bump stop and the business end of it will be tucked in further below the chin pad as was stated above.
Any thought on this?
