Zach and Libby memorial ski build for Mason
Crab
thanks darin...noswad!
Seattle
I have a throttle cable and pump. I'll bring it to the river today....
We have a pump body from an early square, and a throttle cable now, list updated.
DO NOT HAVE!
8. Start/Stop switch -
....Pole spring
....pole bracket grommit assembly
....pole bolt for RN
....fuel primer
....fuel/primer line
10. Nose foam -
....stainless nose piece bracket.
16. Hull hardware -
22. Stator -
23. Flywheel -
24. Flywheel cover -
44. Impeller -
45. Wear ring
46. Pump nozze -
47. Steering Nozzle -
48. Pump bolts -
.....Chinpad???
57. Hoodstraps
58. Limiting Rope
59. Battery
60. Bilge pumps
<!-- / message --><!-- sig -->
I have a long exhaust hose that's been cut.
I believe X-Metal sent it with the waterbox.
It should fit fine.
PS Got the steering cable, too.
Crab
Seattle
DO NOT HAVE updated!
....fuel primer
10. Nose foam -
Strap mountiing brackets
22. Stator -
23. Flywheel -
44. Impeller -
45. Wear ring
57. Hoodstraps
59. Battery
<!-- / message --><!-- sig --><!-- / message --><!-- sig -->
__________________
Flywheel cover is coming my way from Carl/DangerBoy.
Jeremy has committed to bilge pumps.
Crab
Seattle
Oxnard has some things he is sending.:arms:
hood tubes
pump hardware
ride plate hardware
intake grate hardware
motor mount hardware
internal part of grommet assembly
turn nozzle
midshaft bolts
