Parts update. If anything on this list is not correct, let me know.
Crab, let me know what you have.
Here's what I currently have. Ignore the numbers.
1. Hull - Crab
2. Hood - Crab (I got one, too)
3. Pole with steering- Boris
4. Pole Bracket - DangerBoy or Gasgas for stock type
11. Water box - X-Scream!
12. Fuel Tank, ickup, etc - Matt_E
17. Midshaft assembly, or parts - Luke Suva
18. Driveline couplers - Motoman25
20. Ebox - WatCon
21. Starter - SBT
22. Complete 62T shortblock and gasket kits - SBT
23. Carbs, stock f/a's, intake manifold, reeds
24. Complete Limited B-Pipe, from Mario, Phil, and myself
36. Exhaust hoses - X-Scream, also donating a front exhaust! :woot:
39. Steering cable - Talsivar
0. Motor mounts - Kurt, if I am not mistaken
49. Footholds - REV's from Flat Brapp
52. Glassing supplies and fabric - Fiberlay has stepped up and will supply all glassing stuff. :woot:
53. Tubbies, W-Nut. :woot:
55. Hoodhooks - Superjet112x
54. Turf glue, brushes, 5200 - SXIPro
50. Turf - Hydroturf!
51. Ody grip endcaps, and two pisser fittings- Superjet112x
9. Nose piece-
13. Battery Box -
14. Tank Straps -
15. Battery Straps -
19. Coupler cover -
41. Intake grate -
42. Rideplate -
51. Paint -
56. Hoodlatch
I had commitments for parts, but never got them (to my knowledge)
Here's what I do not have to date:
8. Start/Stop switch -
10. Nose foam -
16. Hull hardware -
22. Stator -
23. Flywheel -
38. Throttle cable -
43. Pump -
44. Impeller -
45. Wear ring
46. Pump nozze -
47. Steering Nozzle -
48. Pump bolts -
57. Hoodstraps
58. Limiting Rope
59. Battery
60. Bilge pumps
61. Bilge switch
62. Graphics?
