1. Hull - Crab
2. Hood - Crab (I got one, too)
3. Pole - Boris?
4. Pole Bracket - DangerBoy or Gasgas for stock type
5. Steering system - complete UMI from Flat Brapp
6. Bars - Motoman25/Phill
7. Throttle - Motoman25
8. Start/Stop switch - Thong_Bandit
9. Nose piece- Crab/Gasgas
10. Nose foam
11. Water box
12. Fuel Tank, ickup, etc - Matt_E
13. Battery Box - Flat Brapp
14. Tank Straps - Flat Brapp
15. Battery Straps - Flatt Brapp
16. Hull hardware - I got some, I need to see how much I have
17. Midshaft assembly, or parts - Luke Suva
18. Driveline couplers - Motoman25
19. Coupler cover - Flat Brapp
20. Ebox - WatCon
21. Starter -
22. Stator - Polako
23. Flywheel - Polako
24. Flywheel cover - 2nd Nature
26. Cases
27. Engine cradles - Phill
28. Crank SBT????
29. Cylinder
30. Pistons
31. Head - DangerBoy
32. Intake manifold - T intake, Flat Brapp
33. Reeds - T Reeds, Flat Brapp
34. Carb(s)
35. Exhaust, whole, parts, a/m, stock? Someone said they'd give a limited pipe. If I get a commitment on either a headpipe OR a manifold, I will throw in the other piece.
36. Exhaust hoses
37. Flame arrestor(s)
38. Throttle cable
39. Steering cable
40. Motor mounts
41. Intake grate - Kennay
42. Rideplate - Kennay
43. Pump - SJ/XPBri
44. Impeller - SJ/XPBri
45. Wear ring - Phill
46. Pump nozze - SJ/XPBri
47. Steering Nozzle - SJ/XPBri
48. Pump bolts - SJ/XPBri
49. Footholds - REV's from Flat Brapp
50. Turf - Phill 1 roll of B-stock
51. Paint - I can do the work, if I could get some help with supplies. - Possibly Thong_Bandit for some supplies.
52. Glassing supplies and fabric-Fiberlay???
