Timing is key for sure. Ran 1 gal of 110 with 4 gallons 93 last season. 160 gallons or so. No issues but it was A mild timing curve. I will likely be running 50/50 this season.His compression is too high for a stock cdi or an enhancer. The carb tune needs to be rich and the ignition timing needs to pull back or else he will trash his engine, just like most other riders do.
A lot of rickters with 1200s on enhancers out there. I'd say the zeel would be better but it's hard to ignore the fact that a lot of 1200 dasas on enhancers are out there
You can fill the outside of a barn with what I dont know. But if you can set a zeel to match a TL timing curve, have hotter spark, and run a lightened flywheel with no magnets. Wouldn't that be leaps and bounds better than an Enhancer? As far as reliability it seems to be hit or miss on both the msd and the zeel.They are doing that for a reason.
I’ve run them back to back and I liked the enhancer better.
With that being said I’m sure somebody using zeel will quote me and say I didn’t set it up right.
So I’d look around and see who’s getting the most amplitude / performance out there. It’s hard to argue with results.
Once of my concerns with zeel is I’ve heard many stories where the cdi didn’t last long or had issues. That being said it don’t know what moldes or ara of the unit. Also can’t say that it was or wasn’t install issues or what causes it. Just things I’ve heardI was just about to say basically the same thing. If you could program a Zeel to the same timing curve as the Enhancer, AND anywhere in between, wouldn’t that make the Enhancer obsolete?
I've heard of many, many bad MSD's too though.Once of my concerns with zeel is I’ve heard many stories where the cdi didn’t last long or had issues. That being said it don’t know what moldes or ara of the unit. Also can’t say that it was or wasn’t install issues or what causes it. Just things I’ve heard
