DAG
- Charlotte, NC
Front flip.
I added a bit more info to that post.
That is freaking cool. Love seeing builds like this.I added a bit more info to that post.
I didnt fab up anything, but I have been wanting to buy a welder since I was 16, and today was the day that I finally pulled the trigger! I was going to go with a more expensive Multi Process unit, but instead I bought a brand new Hobart Handler 140. I figured if I use it enough, I will upgrade in the future.
Cant wait to stick metal things together!
Most important thing with welding is cleanliness and a solid ground. Also buy a grinder.![]()
OCD, you can fab up a nice "enclosure" (at least walls) with some lexan (bent by heat) and some magetic socket holders. One of my CNC knee mills was making a mess with coolant, and that's what I did. They are there when you want, and gone when don't.
Engine is 200 mm forward.
Front flip.
Nice innovation. It looks like the motor mounts are WAY too far forward.. I cant think of anything positive that 200mm forward will do for a freestyle ski? What pipe do you plan on running?
Thanks . I do have photos from the beginning, I’ve never started a thread but I’ll give it a crack if you’re interested..That is freaking cool. Love seeing builds like this.
Do you have a build thread going for this? Looks like a fun project to follow.
What's it going in/on? I ran a Powerbomb on a ported 61x for a while, it was great.Fitted a 48 to an oem manifold today. I think it turned out well.
Ive got a 61x cylinder and cases im porting. Stock stroke. Would love to put it in something really light with a 155 and a pfp.What's it going in/on? I ran a Powerbomb on a ported 61x for a while, it was great.
First Project: Hitch hauler for the super chickin.I didnt fab up anything, but I have been wanting to buy a welder since I was 16, and today was the day that I finally pulled the trigger!
First Project: Hitch hauler for the super chickin.![]()
Remember that you can reduce your temp lower than the bottom setting on the machine if you need to by adding extension cords. I have a few 100'ers that are just for that purpose.They old man came through the shop to drop off a new toy..
