- tidewells VA
So I bought a damaged superfreak circus and the through hull drive shaft tube is broken on the inside and at the pump tunnel. Also the carbon exhaust tube looks melted and over heated at the end where it goes into the big exzost tube in back of hull. I will post pics this weekend.
Looking for advice on what kind of carbon and epoxy to use. I talked to Adam at wavedayz I will be putting flexible hose in the middle of the drive shaft tube and exhaust tube to alow for hull flexing. I will have to cut a access hole in the tray to access thees points. I would like to know what type and size carbon fabric to use on the pump tunnel, exzost tube and for the tray. Any advise is greatly appreciated. I have some good experience with fiber glass this will be my first carbon repair.
Planing on using west systems 105 and 205 on the inside along with some body panel bonding epoxy adhesive and possibly some more flexible west systems epoxy adhesives. On the out side I will be using 207 hardner for the outside to prevent yellowing. Need advice on abrasives for prep and fabrics for repair.
Sent from my SM-G981V using Tapatalk
