still no pics of the gp mount beside a sj?
hre ya go
hre ya go
Im not sure about the people just bolting the mounts in, unless with the stock SJ mounts the motor needed a buttload of shims then the GP mounts would take up the space. The only way I can see it working is to mill off the bottom of the GP mount.so how are some guys running 2 gp mounts in the rear, and 2 sj mounts in front.
its clearly a different height from one mount to the other, this is what kept me from using these myself. im afraid it wont align and ill be breaking midshafts.
my question is how is the driveline staying aligned now that you are raising the motor so much?
yesh,I dont see how?
Lets throw more confusion into the mix.... I wonder just how much the motor lifts due to torque under a load?
We can go thru pains trying to align it statically but just how far do things go out of whack under hard acceleration ?
Maybe it's just a big conspiracy .....
Like Demon said - the amount of SJ shaft strips are so rare and probably the ones that did strip out were probably high time and worn out from pump mis alignment.
There's a reason why you find those funny little shims on the back ears of your pump and mid housing on a new boat.... we just choose to $hit can them in our infinite wisdom!
aren't you the one who reuses the same shims one new mounts? I have hard time believing you're actually checking alignment anyway.
and again, how many SJ midshafts get stripped? how often do stock motor mounts break?
for me, I've never stripped a shaft and I've broken plenty of stock and aftermarket mounts.
mine aligns fine.
I think we are only talking about what 3mm? Last I looked I think the manual allows for 1 mm out of tolerance on the couplers and doubt seriously that 3mm is gonna hurt a thing.
The concern needs to be more of the pump shaft alignment than the coupler as noted before.
Talk about a score ~ I just wiped out 3 mounts and found 4 low time GP mounts buried in my garage that I thought I would never be able to use!!!
Thanks guys!
I was told by Gil Beurnier that you need to mill 2 mm off of the bottom to get them aligned correctly. The side by side picture seems to confirm that.
Did you guys ever figure out why ewoks ski kept stripping shafts even though it was shimmed out right?
