The hood is one of the parts we are most proud of, it was designed by a combination of feedback from riders & racers, airbox knowledge from our GP racing development background & functionality.
The purpose of re-designing the hood was to meet the following requirements:
-Allow twice the volume of air as oem hood.
-Supply a positive cold air pressure to the engine bay.
-To work with cutaway in the bulkhead to allow the complete hull to act as a slight pressurized airbox.
-Greatly reduce water entering the hull.
-To hold the front of the seat without seat clips.
-Securely hold the UMI steering system.
-Have a dash to hold tacho,etc that is protected from glare & is on a suitable angle to be easily read by rider.
-Capability of direct mounting steering & trim cable & rem-con trim system.
-Be one-piece.
-Lighter than oem.
-Much stronger than oem.
This was not easy to achieve & actually took more time to design & make the moulds than the hull & all of the rest of the carbon parts put together.
There is 35 pieces that make up the hood inluding alloy threaded blocks & stainless nuts bonded internally for mounting items.
Above are some pics of the foam/bodyfiller hood in various stages. The first pic is the hood getting ready to be primed before the mould can be made.
The air intakes are twice the volume as oem & the angle of the vents are greatly changed to capture air more effectively.
We added a key line around the dash/steering area for the purpose of seperating this area as a defined line as to have a carbon finish dash area & the rest of the hood painted.
The other pics are of the hood primed & ready to start making the mould of the top.
We have had the ski laying on it's side for 1 minute after being spat off in both the surf & the river, up-righted the ski & came straight to shore to see how much water the hull took. On both occassions the complete engine bay had a fine mist of water all over it, but not even enough water for the bildge to pickup.
