Various pics of the motor & pipe in the hull when we were checking out positioning & working out how to mount/fit pipe & rear fuel tank.
The motor is DASA's 200HP 16mm stroker billet power valve motor.
Most components in this motor are billet including:
Cylinder
Head
Domes
Crankcases
Flywheel cover
Crankshaft
Power valves
The work Dasa has done supplying this motor for us is truely a work of art & looks almost too good to put in a hull, have to admit it did look good sitting on the dining room table!
Puting a billet top end on a set of epoxied/machined 62T cases is still very cool, but it does take things to the next level when you know you have the strength/security of solid billet cases holding everything together. I'd hate to think how long it would take to cnc mill a pair of cases.
The motor is currently setup for 98 octane pump gas & is running 185psi.
We have the option to increase comp if we choose with other domes, but want to run the motor with this setup initially as we're sure the power will still be crazy but on the safer side. It's always good knowing you have options if your chasing even more power.
The cylinder & crankcases are ported.
We are using V-Force 2 reeds in a ported R&D Dominator intake with spacer plate.
The ignition is a Flame Total Loss with a custom curve designed for the extra long stroke, using 28 degrees max advance, (again we wanted to be on the safer side & can have more power with more advance if need be).
We are using ada billet couplers for strength & to reduce rotating mass.
The carbs are 48mm Novi's to finish off the complete package
