Half flip95
Formerly pondracer95
- Lake Havasu City AZ
the 08+ was the most stable and predictable boat i have ever ridden. I could hit perfect laps without even trying. Either your boat is messed up or your head is messed up
Interested there is term for this...chine walk...surprised not ride plate...rear sponson....something like that easy fix. I have tried all different stance...riding further up....further back...telling you at medium speed you cannot over power this instability....when turning is gone.....when hit throttle goes away.....however at high speed you think gonna buck off of it. Is the chine walk what sounds like mine does?? Rocking motion but you can feel it coming. Like under the ski something grabs and twists it every other second...very odd. It's pretty strong....did get worse with less gas in the tank....if that helps. I hear of this bondrail cut??? Gonna take out ride some more investigate it more....try have someone better rider more familiar with SJ ride it. If I had bent prop or shaft of bad pump how would I tell or see that....would make noise or feel vibration or something way off?? I talked to orig owner he said far ask now never had something sucked in....this ski his not even to it's 20hr first checkup. Never was any work done to it etc....he did not ride well was older why got rid of it. I had SXR for years wanted to get SJ lighter, more torgue...something different. If do something would be to sell this one buy full modded out SJ. Just cannot believe cannot get this one to be better love this thing...its NEW!!!
This seems to make more sense to me. DJraider traced his problem to the rails but mine does this deflection thing when Im at 1/2 - full throttle. If it was my back rails, then it should do it more often when I am going less than 1/2 throttle since the back end would be down in the water. IT also only does it when im going straight. If I am carving at all I don't have any issues. I also don't have any issues in choppy water. Flat glassy water is the worst. For those of you who haven't experienced it its not really a chine walk or an issue with the ski being slippery or losing traction. The problem is that you'll be cruising straight and then all of a sudden without any warning the whole left or right side of the ski will just dip to the side. the nose doesn't turn one way or another, the whole ski just lays over. the faster you're going the harder it is to compensate for it. Has anyone else come up with a solution to their issue other than always carving?my guess the water hits the built in Tubbies and you get Deflection. I noticed this on my SXR if I was WOT in glass conditions and chopped the throttle. hell, I got pitched off several times when I was not paying attention.
