This is my first ski with a PFP. I was playing around with restrictors today to get the engine temp correct (water temp was around 40) however the water going overboard from the chamber was pretty much ice cold. Should another restrictor be run there as well to keep the chamber hotter? I'm going to talk to Erik, but just want to see what your opinion is.
That affects water box temp, not chamber temp... Probably need to restrict water going to the chamber some more...Should be a jet in the stinger going into the PFP and then a adjustable twist flow control valve...have you adjusted this?
I don't see what's broke?
Bending a rodWhat's wrong with using a rope?
You only put a couple inches in.
That sucks man
