I have no clue what one is worth already converted. Its kind of a new market LOL I never saw anyone sell one converted. I will include motor mount plates for yamaha motor, bearing carrier and driveshaft, and the rideplate. You will need to run a kawi style coupler on the motor to make it work. I need to re paint the top deck from where I did the reinforcements, the back of the hull is cut out to de foam, fix rideplate mounts, and install rear exhaust tube. It will be re foamed and painted over where any glass work was done.
Things you will need to run this:
Kawi pump and nozzle, I think I can throw in an x-2 nozzle if need be
steering and trim cables
aftermarket pole bracket like the billett ATP so you can run 2 breathers in the pole (hood is sealed up)
kart tank
b pipe and atp or x metal waterbox (nothing else will fit)
pole of your choice
Im sure this could be converted to run a kawi motor pretty easily also.
Make me an offer. You could even bring all your stuff and Ill build it with you before you take it at no charge!
