Freestyle 300 SX build FINISHED!
Its been some time since I looked at this. Got everything in my basement where I can get to it easily and put some real hours into it. Trim the drive shaft, re thread and then its mock up time. Im not sure what I will do as far as glassing in something for motor mounts. looks like I will need 1.5" thick bar stock to glass in for the mounts to sit on. I will also glass in some 1x1 x .5" squares to drill and tap for battery, waterbox and gas tank hold downs. once thats done I will lay the orange and black kevlar all over the inside.
not sure, it will be aluminum. so it will be minimal. a necessary evil. I want the motor to stay put. I didnt grind out the 300 sx mount points yet. I may bolt 1/4 inch plate to them, bed the underside with glass, nuts and bolts. (flush mount allen head bolts) then just bolt whatever thickness risers on that for the final pads for the mounts to sit on.
-thats what was in this one when I got it, I think the guy had a 650 motor in it. Could work, but the rear mounts will have nothing under the plate where they will bolt. it will be hanging back about 6 inches from the 300 mount in the hull, unless I set the motor forward more. I was only thinking of fitting a gas tank in there when picking how far back the motor will sit. I really want to run a stock RN tank in it. anybody got one to part with?
Did some mockup this morning. Im really considering keeping the driveshaft at the stock 750sx length. I used some aluminum bars that came with my 300 from the last owner that had a bigger kawi motor in it. Looks like I need 3/4 thick x 3 wide and 16 long bars to bolt to the stock motor mount bosses in the hull. Im about to order aluminum today. My only issue is what alloy to use to hold threads best? 6061 or 7075? Or do I get the ss nuts that hold the pump in and glass them in behind the aluminum bars? My other thought was go longer with the bars, and run them back closer to the bulkhead so I would have the option down the road to run a shorter shaft and easly set the motor back further if I wanted to. Also keeping in mind battery placement, fuel tank, exhaust and waterbox. (none of which I have yet) Im thinking of a 4lb bulkhead mounted battery this would save space up front.
The metal plates we used on another 300 project were 1/2" thick. We bolted them to the original mount holes and tapped new ones where we wanted the motor to sit.
thats what Im doing, going to bolt them to the stock mounts in the hull. only issue I have is there wont be anything under the plate for about 6 inches rear of where the stock ones are molded into the hull. I want to bolt them in, mark it out and build a dam with tape so I can pour it solid under the whole plate. I dont trust the 300 hull, its so brittle. All this thing has to do is land upside down once and tear the mounts apart. Im taking it further and making something solid for the plates to sit on and bolt to along with whats already there. then after that the whole inside will be laminated with carbon/ kevlar
I ordered my aluminum bar stock, went with 6061. Now to find a b pipe, decide on a gas tank and do a ton of other stuff. Stay tuned.
Oh, I also ordered something from USC called "All Resin" bonds to SMC and fiberglass. 50 bucks for a gallon.
I got a bunch of cool stuff, and more on the way. I got my metal plates and ss allen head countersunk m8x1.25x35 bolts to mount them to the hull. Also I finally found a b pipe and bought it before it was gone. This weekend I would like to have the motor bolted down. Next I will need some help finding a fuel tank thats going to work. I may call on someone to get me measurements on a RN tank.
