Its finally dry enough to fool with , it's been really cool here for the last few days , I love the weather but the epoxy doesn't .
I wanted to sink a chunk of aluminum into the ski for an attachment point, so I did , the piece is probably 3/8" thick , I cut most of the hole out with a grinder and metal cutting disc and the rest with a hacksaw blade and dug the piece out .
I dug the foam out so it sits much lower than needed , put some Gorilla glue in there and put the piece back in , the piece already had a hole drilled in it so I used a drill bit to grab the inside of the hole and manipulate the piece where I wanted it , the Gorilla glue of course keeps expanding .
I quickly put the piece I had cut out back in the hull and used a piece of Aluminum plate and duct taped it to the hull to keep it in place, if it rises slightly above the surface no biggie , I will grind it and glass over it anyway.
