Case porting/epoxying is done by many builders without problems.
What is the 771? Is it a 61x build?
Wiseco makes custom 2.2 stroker pistons for our MR2's, I'm pretty sure I could get them to make whatever we wanted. I think there is a minimum batch of 16 though.With so many resleeved big bore setups around , its to bad no body makes bigger pistons for these such as 87 or 88mm. There is pleny of sleeve thickness available...
Anybody know what the going price is for a new Lamey ? What is the max bore size on one?
Yea that is a lot. I'm gonna big bore my 61x this winter and be done with it.
Ride one before you get one. I know alot of guys don't like the BB 61x. I know Team Scream does a pump gas 62t freestyle package and from what I hear it is awesome. 200+ psi and pump gas safe if I remember correctly.
By using a decent ignition curve i bet200 psi and safe for WOT runs on 93 octane?
how so?
$2800 for the BIG cylinder, Wiseco pistons (based on CR500 pistons), head, domes, o-ring kit, and base gasket (no girdle kit required). I think it's $250 ish to have the tops of the cases machined to fit the big Lamey sleeves. The max bore is 91mm, first bore is 89. Mine is set up for a 8mm stroker, but they might be interested in making one for stock stroke motors.
Aaron
Yes, an Advent is part of the package.By using a decent ignition curve i bet
personally i would rather go with a total loss than an advent but each to there own
