650sx build by: my650sux
The pole is minus 3 inches and the straight bars (non 15° factory bars) are minus 2 inches. I haven't drilled the hole in the front or cut the holes to run cables yet. Oh and I still need to make a chin pad and spring set-up.
@speedysprocket will a lighyer flywheel make a big difference? The only experience I have with light flywheels are on turbo hondas, makes pulling out hard with a puck clutch due to the lack of rotating mass. I also own a kx125 and when ridding trails the engine is either on or off. Maybe because of the slip between jetpump and water it wouldn't be as bad on a ski. Let my know your thoughts and cost estimate on machine work. I suppose you would have to turn it down on a lathe then balance it.
I do a lot of them and never a complaint. There's not really any benefit to having excessive rotating mass in a jet ski drivetrain. I charge $65 and includes balancing, paint, and return shipping. Send me a message if you're interested.
Vumad
Super Hero, with a cape!
St. Pete, FL
I have a #0 flywheel. Can't say I noticed a difference. I'm very picky about my power band so I can say it didn't mess up my rev. I hated my KX125. I like a linear power band. Love the 4-strokes. Very please with my superjet.
Here are some pictures of the mount/ adjuster I made for the steering cable. I used stainless brackets that I stripped off the wetjet before taking the hull to the junk yard. 20160801_203814.jpg 20160801_203833.jpg 20160801_212617.jpg 20160801_213404.jpg
20160804_193611.jpg 20160804_175835.jpg 20160804_193622.jpg so my project is moving along nicely. I just need to measure and shim the motor, finish the jacketed pipe and have another go at the waterbox. I think I'll have it running in a day or two. I'm thinking about pulling all my stickers off and putting them on my yeti so I can paint this thing. I really should have waited to turf it.
I have finally started working on my pipe again. Last night I welded the doughnut flange to my expansion chamber. It's offset downward at a 15 degree angle so that it has plenty of clearance and will run right into the waterbox. Keep in mind this is only the inner layer of the jacketed pipe, I will be putting another layer over top of this one with and air space in between them. This will be achieved be building up the welds and breaking up another belt and cone 1/2" larger in diameter than the inner belt and cone. 20160816_215208.jpg 20160816_215237.jpg 20160816_215714.jpg 20160816_215941.jpg 20160816_215327.jpg
I did the math months ago and that's what I came up with for size. I figure it's easier to make it smaller than larger. I'm not sure what kinda egt's I'll have with the dry pipe, the hotter the faster sound travels.
