I have been working on the X2, just haven't been posting any updates.
Picture 1 - is the battery the way I intended it to be, but it was tight on the wires, so I turned it.
Picture 2 - is the battery the way I have it now with the wires hooked up. I need to add silicone but it's otherwise done. Theres no straps since it's a snug fit and the seat holds it on.
Pics 3-6 - Layout of the exhuast, the fuel tank and the ebox. The Exhaust is a 650 westcoast manifold, with a 750 Factroy head pipe, connected with a cut piece of silicone, with a superjet chamber, into a 2" - 2-3/8" 45 degree reducer elbow, to a superjet water box, into a 2-3/8" - 2" 90 degree reducer elbow, to a 1' section of marine exhaust hose, to a custom welded stainless exhaust elbow. The fuel tank is a stock 550 tank. The ebox is held on by the stock water seperator bracket and a bolt through the fuel fill area. Internal fill atm only.
picture 7 - Shows the stock Superjet airbox on the Kawi motor, I had to keep the K&N spark arrester base to lift it higher to clear the motor.
picture 8 - The exhaust outlet, a fishing rod holder, the tube was used to make the exhuast outlet, then the base of the rod holder was stretched and 5200 over it to protect against the rough exhaust edge
Pics 9-10 - The 2 seats I have, I kept the stock seat bracket and secured the seat on with a clip and hardware. I may go back and use 2-4 clips attached directly to the seat, but for now this works. When I went to use 4 clips and remove the stock bracket, the back end of the seat would slide a bit side to side. The bracket helps hold it in place laterally.
