AlbanyMotorsports
Cru is Rad
- Chicago
on the 87mm pistons do you need to do anything to the cases or will they clear everything?
jeff told me that on 87mm bore you dont need the pvs
what are you guys doing?
jason
I am running the gas valves..Havent run one without yet.
With 87mm pistons you will only need to knock off a small amount on the exhaust side of the case (i believe) ..just enough to allow the skirt of the pistons to come all the way down..You will realize what needs to be ground when you put a piston on without the jugs and. Im a total hack with a dremel and even i didnt mess it up.
