dbrutherford
Parts Whore
- Fairmont, WV
I am in there in spirit too... One of these years I will go, I just can't afford it yet. And I am not going back in debt ever again over Jet Skis! Cash only from now on.
Introductory pricing, $210 shipped usa, plain steel bare and blasted, ready for coatings, made per order. I may make some and do ebay at some point as a buy it now. (waiting for pics from Willray.
Does that mean they are built the same as stock Kawi plates (once they are coated of course).
No Mike, wings similar to what yamaha does only out of steel. I did the one for Will out of 3/16 x 2" flat stock, but will probably switch to 1/4" for a little added strength (although perhaps not needed) for those who run a little hotter setup. Anyone ever seen a stock bedplate rusted out to the point its unusable???:trink26:Does that mean they are built the same as stock Kawi plates (once they are coated of course).
The secret to coatings, paint or other is to prepare the steel properly by blasting. Then use the correct primer and topcoat, even powdercoat will do better with the proper primer. I wouldn't hesitate using rustoleum after using their bare metal primer, just fixed up my 250 gallon propane tank with it. Another option is galvanizing, but probably overkill. Either way, they will be clean and almost look like they have some kind of coating on them, but its just from being blasted. (;perhaps I should prime them?)What I ment by how it is bilt was more of a corrosion based question. The stock plate is steel covered in a powercoat or something like that. By made the same I mean is this the same material as the kawi plates and will hold up just as well (or better or worse) than that material in the salt (After they are covered, and if the covering avail is better than what Kawi offers).
I don't know much about different kinds of steel and coatings when it comes to holding up. I know the Kawi plates can last a long time. I wont be buying one soon as I'd have to get a motor too, but curious as to how they will last. Also, how much does coating run?
Hey addict... is that just a sj mod chamber?? you think there is room for my blaster limited chamber or should I be looking for someone to swap with???
FOR ANYONE INTERESTED...factory pipe has some sj mods in stock. my buddy got a nice shiny new one last week!
They are so nice.. sucks when your throwing it in for the first time and put the first big scratch in it.. lol
