Im not one that usually gets involved with key board heroes, but I will try to put straight some of these negative posts.
With the warranty claim from JP Weeks, I did not knock him back because he bought it second hand, nor because it was more than 2 years old, with no answer from him how this happen, its was my opinion that under normal freeride abuse, this system along with every other system around the globe, could not have failed , and for the record, zero have. To me its been in some sort of roll over.
Now to address Modular Junks claims: Its unfortunate what happen to you, but its also a bit tough to hold me responsible. Your steering was in the first 18 sets to be sold in the States. Only a week or so after they had landed, a design flaw [which had not showed up in testing] became apparent in the stop tag. Straight away, this Stop tag was reinforced, all steerings sold to that point had replacement shafts with the new stop tag expressed posted to them. 18 replacement shafts were sent to chris along with $17 per shaft for him to post out. As far as I knew, this had been done. Only became aware that he dropped the ball on this months later when yours failed. He told me he replaced the steering cable for you as he knew he stuffed up.
Now you claim other parts of the system broke and you have photos to prove it. Im calling on you to back up what you say and put up the prove. You also claim you spoke to me, im guessing on email, I don't even know your name, I say you never have and feel free to prove otherwise.
So to end this, I fully believe these systems are built tough and will not fail under freeride conditions.
