Freestyle 96 rn winter build and nose job
CT
When you put in your footholds did you glass the bottom flat then put the footholds in and foamed more and glassed them in more. Im gonna be putting my adjustables in tommarow and was just planning on foaming it all at once with the footholds in and glassing it all at once.
On a table on top of plastic, once that setup, mixed up thickened epoxy and glued new tray on top of the flat part of pump, and then on the lip right below dash, then tied in tray to sides, cut the bob foot holds up to get theme to sit as flat as possible, used thickened epoxy and glued theme to the walls, then tied foothold in and then rest of tray
CT
Thanks appreciate it. Got mine today and layed them in. I did some trimming on the tops of them to the the backing board to be flush with my gunwells. Ill be doing a cabosil mix to glue them in and then foam and glass.
Got some glassed on the inside on the bottom side, and sides 3 layers of 12oz biax no flex and havent got top section tied in yet, itll prob end up getting a layer of 6oz cf twill over it to when i reinforce rest of bay, weighs in at 115 right now not to bad i dnt think for a stock hull, recieved my rrp bracket, i like it alot,
Byeai
"Cheetos-Man"
Melbourne FL
nice mine wet foam no hood was 130 reinfored fully before I started tearing it all out to redo
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Byeai
"Cheetos-Man"
Melbourne FL
lol yea I just defoamed it and cut my nose of and took out most of tge reinforc ment so still have to wiegh it again the nose I cut off was 10 pounds tho so say 120 with out a nose
I had to cut a lot off mine as well. I pretty much cut most of the bottom off and trimmed the sides to the backer board. Can't wait to ride with the bobs, The tray feels so comfortable now.
I'm not for sure exactly how many. I had cut a bunch of pieces and just starting laying them in the nose and pole bracket area till it was all used up. Maybe 4-5 layers 12oz and 17oz biax topped with a layer of eglass. When I drilled the holes for my pole bracket area it was 3/8" thick. Feels very solid.
