Finally some more progress. Man that first hole you drill into your shiny carbon hull is a bit traumatic. Painters Tape, then measure, measure, measure, re-measure, then close your eyes and just do it!
The rubber backed bow u-bolt from West Marine is mounted and ready to make transport and towing easier.
Watching Phil align a pump shows his attention to detail, no worries from me about a stripped driveshaft.
The midshaft housing is sealed and bolted up. Due to the alignment of the pump, we had to shim the midshaft housing and on my (cheapskate) call we decided to use the Right Stuff to seal the housing to the firewall. On hindsight, maybe I should have bought a cold fusion midshaft housing spacer and had that ground down the .7 degrees it needed for alignment.
Couch mounts are installed and the mounting holes are drilled out a lot, and it's still not level enough for Phil. So we grind the bedplates, on my shiny new TPE 964. He's gonna grind/sand the mounts down 20 thousands to ensure proper alignment.
Slow and steady goes the build. On the upside, the way it's being built, I shouldn't have any issues with the way it runs.
The TPE 964 looks awesome inside the hull and I can't wait until the first time I get to hear it crack to life!
![20131124_175426[1].jpg 20131124_175426[1].jpg](https://www.x-h2o.com/data/attachments/149/149057-dce82457f9a10ac7b40d04bc5f9016f3.jpg)
![20131124_183349[1].jpg 20131124_183349[1].jpg](https://www.x-h2o.com/data/attachments/149/149058-281e3e15bbbed27ad9af5e4966bf2e77.jpg)
![20131124_183403[1].jpg 20131124_183403[1].jpg](https://www.x-h2o.com/data/attachments/149/149059-2571643e8487b4ace0c88ae77594fefd.jpg)
