Freestyle Affordable Power......... It's COMING
Yamaha 62t based. No sleeves, nikasil plated. The motor in the vid was straight out if the mold with no additional work other than machining the bore for nikasil. But, Erik can set you up however you want.
Scottie
Crab
thanks darin...noswad!
Seattle
Scottie
shazzam, im in...
It's been a long time coming. Erik has worked on every little detail on this setup. And final a cast setup so we don't have to deal with the heat problems of billet and the high prices of billet.
964Chris
FREEdumb obtained
TEXAS
Erik is the man! Good times in Daytona, lots of good conversations and insight...........can't wait for these to hit the market. Gonna make some big waves when they come out. Look out Oz.
The pistons have been run in the am atv and snowmobile markets with great success for some time now. Their expansion rate has already been mapped and matched to the cylinder. Because they are already developed and we don't have to pay for the initial r&d, the cost will be $160 ish each. They are flat tops.
We will have pump and race gas setups. The test was on a 195 psi dome config.
MORE TO FOLLOW
