Byeai
"Cheetos-Man"
- Melbourne FL
Over a year on one of mine
Sent from my SAMSUNG-SM-G925A using Tapatalk
^good to hear on the AG. Special charger I'm assuming?
Mikee, you need the Optimate charger. Plug it in, walk away.
Yep I think same one as Matt had last year right?
While an Anti Gravity battery may say 12 or 16 or 20 cells, they organized (combination of series and parallel) such that it behaves as a 4 cell. So set your RC charger to 4 cells (should be 12.x volts) and charge away. There's also no balance port on the AG so you can't get individual cell health. Makes it simpler for charging.Yes, I bought Matt's Optimate.
Like Phil said, there are more precise chargers out there, that will return data on each cell's health and balance individual cells. So far, some guys in our group are on their second season with their PHP Ballistic batteries using Optimate chargers. This is my first Lithium battery in a ski, so I will try to update this thread on any issues and the longevity.
@Philip Clemmons are you using an R/C charger to balance your individual cells? I've considered trying this, as I have Lipo car packs that are over 5 years old and still balance out close to perfect every charge. My R/C charger has a LIFE setting, but it only goes up to 6 cells![]()
So what is any new feedback out there. I had a WPS poop out on me last year but sure it was user error, very sure lol. Im kicking around between the PHP/ballastic battery, antigravity, and the battery tenders. How have these newest models been holding up? I will be running TL on a 1100 pump gas. I don't mind the 8 lb motorcycle battery's weight but heard after a few months just won't cut it. Thinking about doing a WPS again but heard a lot more about the above three mentioned.
I have don't have a big issue with the Optimate, but I've seen guys have issues while using them. They can't however balance cells without a balance connector. No charger can do that. Cell equilization charges can help to equalize cells, but should not be confused with balancing. Voltage is potential difference. By nature, a cells with higher voltage will try and pass voltage (electrons) to a cell with lower voltage. Applying a low current, slightly higher than normal voltage can help cells to equalize. The difference from balancing is that balancing turns off the charge on the cells that are charged, and continues to to charge the low ones. In an equitation charge, it applies voltage to all cells in hopes that they equalize.@Philip Clemmons Thank you for explaining the batteries, chargers and reasons for failure. Hopefully everyone interested in running these lithium batteries takes the time to read and digest this information.
Let me know when you have a charger available, I now realize that the process the Optimate is using is wrong. So is the last 12 hours the Optimate runs a "load test" and recharge, their way of equalizing/blanancing the cells?
