Ill be making the switch from tl to jetnetics and an hx3 after wavedaze. Ill let you know how it works.Has anyone tried the jetnetics with the hx3? It worked fine with the old epic
Which jetnetics will you be trying, is it the newer steel hub wheel ?Ill be making the switch from tl to jetnetics and an hx3 after wavedaze. Ill let you know how it works.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
YesWhich jetnetics will you be trying, is it the newer steel hub wheel ?
Will the hx3 work with 61x stator and flywheel or do I specifically need a 62t?
The old epic worked with 61x.
Ya it's a good question. Airtime site states 62t charging.
When I had all those issues 62t stator was one of the first things Airtime verified I was using
My enhancer works with both 61x & 62t
Have you emailed Chris? He is very good at helping you through issues like that.Lightened stocker, new coil and new stator. Still having issues. The epic might just be bad.
I have been dealing with Chris all along. I swapped ALL the other items from stator to coil to rectifier. finally the only resolution I got was installing a stock cdi on my 1105 with a dry pipe. even with the instant rev limiter it ran better than it did with the epic. so far I have wasted weeks of time, bought a flywheel stator and a bunch of other stuff. now I'm told I need to send this to the UK to have it inspected and then if it tests bad I will get a replacement. with any luck I'll be riding by august. I am not the most happy person right now. I'll be putting total loss back on for a few weeks I guess.Have you emailed Chris? He is very good at helping you through issues like that.
funny my serial number says OEM B 117 _ _ _ _ so maybe that's the issue?Your using resistor spark plugs too I would imagine, don't want EMF frequency disturbing the CDI's operation. I'am sure you know this already just thought I'd mention it.
Have you tried the MSD's enhancer curve to verify it's not a timing curve issue ? When I run different curves, I've found that flat portions of the curve before the advance or too much timing too early make the ski sound and run rough/poorly with poopy throttle response during these portions of the curve, but when the rpm's are up at a point where the engine can use the timing it sounds normal and hits like a mofo.....
The enhancer curve is a simple test to eliminate a curve issue
Your Cdi is flashed back to OE flywheel, TBM was flash 117
Chris at Airtime has been great on tech issues btw
Edit: when you connect to the Cdi the flash prefix is in the part number displayed, if it show 117 in the part number your flash is for the TBM wheel and needs to be flashed back to the OE part number for use with OE wheel
