The 117 flash was made to correct the timing issue caused by the TBM's designed weaker magnetic signature, so with this flash your timing may be skewed and incorrect with the OE wheel. When I switched from TBM to OE I flashed it back to the OE file.
If you email Lisa at Airtime she will send you the file link good for 5 days, so far iam not sure if I see it on my computer, iam still checking for it and other related info though
http://www.airtimeproducts.co.uk/index.php?act=viewVID&vidId=41
Edit: Ok I checked the file prefix for the TBM wheel is "TBM B117"
Prefix for OE wheel is "OEM B117" so your at the OEM flash level already
I did see my last two digits are 35 and yours is 75 not sure what that's about
